Chassis system failure - what is it likely to be?
pwebb
PCGB Admin
So this morning the 2018 Cayenne with air suspension threw up the fault; Chassis system failure - Park vehicle safely.
There was a strange couple of clicks when reversing which I thought was a stone between the pad/disc or a stone trapped in the tyre.
The air lift doesn't work.
Spoke to my OPC who says not to drive the car at all so it will have to be trailered in.
Any ideas what it could be? Compressor, air bag, battery?
In my experience can be a sensor failure rather than a system failure. For example an ABS sensor failure triggers 6-8 warning lights for failed systems including chassis but it is the sensor not the system that has failed. Sorry don’t have the technical knowledge to suggest which sensor in this case.
It’s a possibility, I’ll try and get the codes read, but a bit tricky where I am atm.
