Hi all,
Being new to Porsche ownership and PCGB membership, every day is a school day at the moment. When I purchased my Pan 4 in July, it was in need of some TLC and the first thing I arranged was to have the brake fluid replaced. I booked it into Wolverhampton Porsche (about a 3-week wait for the appointment) and was quoted a price for the brake fluid change and a ‘healthcheck’. I wanted to use the OPC to ensure the car was checked and the correct fluid used. More emphasis on the former but driven by the need for fresh fluid.
On the day of the appointment, I was well looked after, advised again it would be about 2-hours - I’d already planned to do some work while I waited for the work to be completed. Bang on time, car dealt with, fluid changed, tested and report provided. Everything was as expected and great service - both warm and welcoming.
The twist.
My healthcheck report advised a number of points e.g. puncture kit out of date, the two front tyres were not N-rated and the two front tyre valves were slightly perished. I arranged to have the tyres checked and valves replaced at my local Kwik-Fit.
Problem 1- on placing the wheel and tyre on the tyre removal machine, the clamp that comes down to separate the bead went straight through the sidewall of the tyre.
Problem 2- ditto the second front tyre when the clamp caused two large blisters in the sidewall. At this point, they stopped and called me over to explain the issue.
Transpires that although both fronts had 5mm tread across each tyre, they were manufactured in mid-2015. Given the incorrect tyre rating, I could have very easily blown a tyre when I was on the M6/M5/M180/M18 during my trips in August.
In the end, Kwik-fit did me a great deal on two N1 rated fronts and I now have 4 OEM recommended N-rated tyres and a higher level of confidence in their construction and composition. They checked the rears and I’m pleased to report that all is well with them.
So, to conclude, great spot by Wolverhampton Porsche on the tyre issues and great service by Kwik-fit. It just goes to show how the proper rating needs to be checked and adhered to.
Onto my door lock issue next…
The twist.
