Hi all,
Has anyone come across this error. "Reverse gear not available, ok to drive on”?
Prior to this there was no warning signs anything was up, car was driving beautifully on the drive back from Goodwood. Went to move the car on Sunday and the message popped up, car wouldn’t go into reverse. I thought this must be the car having a wobble, so I left it for a while and tried again, same issue.
Called a local garage and managed to take the car in, only 2nd gear was available! after running diagnostics one of the sensors was reporting not enough voltage, should be 5v but was fluctuating between 3v & 4v. Other sensors were reporting correct voltage
Does anyone have any advice in this. Porsches answer is to replace the entire gearbox
Model: Cayman S - 2013
Thanks Paul
Thanks Paul
