Helpful ReplyHot!Advice on knocking noise.
Ballintra
Ballintra PCGB Member
2021/07/08 23:37:49 (permalink)
Loving finally being a 997 gen 2 owner   but looking for some advice.
When driving on any rough road surface ( and the roads in Glasgow ain’t good )   I am experiencing a  “knocking“ sound, I have had inner and outer tie and track rod ends and coffin arms replaced but it’s made no difference. What do you think could be the problem or is the knocking “normal“
Thanks for any advice .
Jim
msamos20
msamos20 PCGB Member
Re: Advice on knocking noise. 2021/07/09 09:17:41 (permalink) ☄ Helpfulby Ballintra 2021/07/09 21:34:34
Owned 2 997 turbos.  Had vague knocking sound.  Had. Mot done was failed fractured rear offside spring was surprised !  Hsd both rears replaced. Argued that should be covered used Porsche warranty they  paid up eventually.  Sorted vague knock !
Hope you get sorted Martin
997 great cars
m s amos
Motorhead
Motorhead PCGB Member
Re: Advice on knocking noise. 2021/07/09 09:56:38 (permalink) ☄ Helpfulby Ballintra 2021/07/09 21:34:22
Jim,
Although sound is directional, in an enclosed cabin very often it’s difficult to establish if the knock is coming from the front or the rear of the car.
The front strut top mounts can also be a source of knocking sounds if you’ve not had them replaced. There are a lot of elastomeric bushes in the multi-link rear suspension which will have deteriorated with age, any one of which could be the source of your knock, so unfortunately it’s just a process of elimination, and a lot force is required to check for play in joints in a static set-up.
987.2 Cayman S
North Beds (R10 & R24)
STiG911
STiG911 Guest of the Club
Re: Advice on knocking noise. 2021/07/09 15:48:30 (permalink) ☄ Helpfulby Ballintra 2021/07/09 21:34:19
Seconded for possible top mounts. Very common on all 997 models.
Reuben_997
Reuben_997 PCGB Member
Re: Advice on knocking noise. 2021/07/30 18:15:14 (permalink)
I would suggest the front fork arms. Mine were shot on my .2
Replaced my coffin arms, fork arms and inner tie/outer track rod ends.
Top mounts are prone to making noises as well...mine speak every so often...but do not knock.
I temporarily used a set of H&R springs, as I am still waiting on my Bilstein's to come in & re-used my top mounts. In an ideal world, I would have changed them out for the new ones too - but decided to wait until the new suspension arrives.
It's made a world of difference, with no knocking noises at all and a tighter feel.
Reuben
997.2 Carrera S PDK
