Zunsport Grills
Dick Dastardly
Does anybody know of anybody that supplies and or fits Zunsport Grills in the Nottingham area?
I am aware that they need to be fitted to be taken out for extended warranty check.
Being forced down this route due to condenser issues with the 992, I will report further on this as things develop.
Neil
Hi Neil,
I ordered a set direct from Zunsport in Cannock two weeks ago, they arrived to our home in Leicestershire within 2 days of ordering and I was able to fit them very easily. I was also concerned with the exposed radiators. My car only has the two as the centre one is a blank. They will usually do you a 10% discount code when using the website.
Here is the link.
https://www.zunsport.com/en/porsche-grilles/porsche-carrera-992-c2-c2s-c4-c4s-outer-grille-set
Regards David
Zentrum at Calverton supply and fit Zunsport grilles.
Last time I went they had a Zunsport display in reception.
Give Mike or James a call and get them priced up.
Like David above, I actually ordered mine direct from Zunsport and got a 10% or something discount.
Though that was over 4 years ago and for my Boxster which is probably a much simpler home task than a 992.
David says easily fitted though. I guess they all fit similarly.
Get on the Zunsport website and put the code in.
The 992 grilles fit in front of the louvres, whereas I remember my 981 Boxster were behind.
