Engine machine shops
richardstephens777
Can anyone recommend any machine shops near Surrey or Derbyshire.
I need my 930 heads machined and valve guides changed.
Location does not matter too much.
Many of the companies I know are not operating at present.
Found a great workshop. David Moore Engineering in Godstone Surrey.
https://www.davidmooreengineering.com/
Working on my 1983 heads, checking the valves and putting new valve guides in.
You can see at the top left where the exhaust air has been escaping.
i had my 930 engine top end rebuild by by SCS Porsche in Honiton (Devon). They use a very good machine shop. It would be worth giving them a call if you are stuck. These guys are excellent and did a fantastic job doing a top end rebuild on my engine. Speak to Andy or Stuart.
TIM
I can't recommend SCS Porsche and Andy in Honiton (Devon) enough, they took on the re build of my engine after another mob which name I can't share did an absolutely terrible job on, more leaks than a sieve!
SCS a pleasure to do with business with, and still running well sweat since 2017, I must book up for a service soon.
Book your car in and have a night in the Masons Arms Branscombe, ask Any nicely and he will even lend you a car to go there.
regards
Kev
regards
Kev
I’d endorse that - on both counts
Hi Hermes, David Moore did a great job doing my 930 heads. He used his own valve guides and machined each one to each of my valves. He is a Ferrari trained Engineer. The engine is back in the car now and runs great.
Rich
