I run a 4.2 S with what I believe to be 350mm front discs. I know the Turbo S runs 380mm discs.
Would I be correct in saying they both use the same calipers? Just different colours.
Would I be correct in saying they both have the same front wheel hub? Which the caliper would bolt too.
What is used to move the caliper further out to accommodate the larger disc?
I can't find any info on the web at all.
Can anyone shed any light on how I can put larger discs on my V8 D?
