987.2 bonnet release fail
Alfaroberts
Just found the electric bonnet release stopped working! Key fob activates ok and rear boot release is ok.
presume a fuse, so hopefully simple DIY job??
advice gratefully received as ever.
thanks for reading
David
David,
I think the fuses are your first port of call - check the listing on the inside of the fusebox cover.
If that doesn’t help then the problem could be with the switch itself, in which case the application of some contact cleaner might help either with the unit in-situ or removed, although if you remove it you’ll be able to check the switch for continuity.
