996 Middle Brake Light Catch
Ian_959
If you're looking to swap out a centre brake light bulb then I suggest it's worth having one of these (or at least this is the part number if you want to order one after the event) its the brake light strip catch hidden under a false cover. You just turn it with a screw driver to release the light bar. But they are old brittle , little and ping easily. Thanks Ian
