Old photo
tscaptain
PCGB Admin
This was posted on one of our local SW classic car club's FB page.[:)]
"Amazing shot of two German ladies making light work of a 356 chassis outside the Porsche factory in Zuffenhausen.....taken off a history page"
In the next frame you expect to see the chassis vertical in the air, then #3 is flipped end to end !
What Club was that ? We are seriously thinking of migrating down that way, Honiton or more coastal ..
cheers, Maurice
So If we had built them in the North we could have halved the work force. But seriously a very nice photo and think how times have changed with regards to automation.
Ian
When I worked for Renold Chains Ltd where all factory handling was either overhead conveyor ,platform trucks with special work pallets or FLT's,I got sent to Germany to another chain manufacture they had recently bought,Arnold & Stolzenburg GMBH in Eibeck ( a fabulous Bierstadt).
This clever company had integrated all the chain assembly machinery into one machine ( called a relay) which not only produced completed chain continually but in required lengths & "proofloaded" each length automatically then wound each length into a coil.
Whereas,Renold used at least 3 machines plus the final assembly relay plus separate "proof loading",as they could guarantee perfect quality by separate inspections-the Germans had incorporated sensors to eliminate this problem.( there is a lot more to it than this simplistic view)
The factory mechanical handling consisted of metal work boxes which were pulled around the factory floor by workforce members on steel bars set in the concrete using long steel hooks onto the box handles.This was in 1964 !
