986 Throttle Valve Switch Wiring
shouy
After changing the starter motor on my 986 2.5, i noticed the cables at the plug of the throttle valve plug had been soldered as a repair but had broken off. I can remake the cable ends with new pins but i am unable to find the correct colour sequence for the plug, has anyone got a picture of the plug and its attached wires so i can put mine in the correct place in the plug?
Welcome Jonathan!
This is the throttle valve potentiometer wiring from the 1998 wiring diagrams. Is it what you are looking for?
