Since initial issues with the lithium battery power drain I am fairly confident the car can be left a few days (7 the longest) without
electrical failure because the battery has disconnected. Obviously the car has little use whilst lockdown remains and I feel I should have established rear wheel steering requires a lithium battery when the spec selection was pencilled in.
Whilst spending quite a while reading through the handbook I am unable to find reference to the voltmeter bar readout which at present
moves to the halfway point . Is this showing the rate of charge or how much charge the battery has (ie as on i phones). The voltgage reads between 13.1 and 13.5 and seems to fluctuate between these readings even after 20 miles.
Any observations would be most welcome
