alastairpJon,Key stuck in the ignition usually means flat battery.You need to open the fuse box cover in the drivers side footwell and pull out the fitting to allow connection of jump lead or battery charger (positive).Negative (earth) connected to body work (I use static part of door latch on B-post).Car will then respond to allow access to front compartment, removal of key from ignition etc.Hope this helps.Alastair
