Headlights
My headlights have stopped working when the switch in engaged. Sidelights work, fogs front and back are ok and main beam is ok when you hold the stack. It doesn't work when you put them on perm. I've checked the two 15A fuses in row A and they are ok. I haven't replaced the bulbs so maybe they have both failed at exactly the same time. Job for tomorrow. So that leaves the switch itself. How easy is it to replace? Any thoughts always appreciated and yes I will buy a new bulb to check they haven't both blown together.Thanks
Cheers Andy. Ive been trying to get to the bulbs. I have removed the headlight unit and then then back section that exposes the back of the bulbs. I can get to the big one that is I think the foglight but the one underneath that I think is the main beam is impossible. I just want to check they are ok. Any tips for getting that out without breaking something?
