blade7
Well-known member
So, fitting a new starter today and seems I should have taken a pic of the wiring connections when I took it off. There's the small wire that has the 8mm nut, 2 wires with copper terminals that go together on the top stud that have a 13mm nut. And 4th wire with a silver terminal and red insulation. It's this 4th wire I don't remember it's place? Not the connection between the starter and solenoid.
