Power drain from Bluetooth kit?
PhilC4S
Hi, I recently installed a tranzit blue Bluetooth kit in my C4S. It works well ??. However, I have had a flat battery since I fitted it. I don’t know how old the battery is. I followed a video on you tube and took the power from the live to the cdr23. Is that still live with the car locked? I can still find the tranzit blu transmitter on my phone with the car locked. If so, where should I take the live feed from to avoid a potential power drain?
cheers
Phil
Yes, the power feed to the CDR is a permanent feed. The easiest way to get a switched supply is to use a fuse tap on one of the fuses that is a switched supply. Fuse E8 is a popular choice.
Thank you Richard. I was at the limit of my electrical prowess when I followed the YouTube video and spliced onto the live feed to the radio! How do I tap onto a fuse? Do I have to lead a wire from my bluetooth device to the back of the fuse box? Or do I find a suitable live wire as it travels somewhere else in the car from the fusebox?
Thanks for any help
Phil
