911sc 1983
Malc458
Hi. Can anybody tell me how to remove the fog lamp switch on the dash. i have removed the black round front part
According to the Bentley Manual for the 911SC, you unscrew the knob in a anti-clockwise direction and then use a 2-pin spanner wrench to remove the retaining collar holding the switch in.
To get to the switch itself you then remove the fresh air blower and plenum from inside the luggage compartment.
It recommends disconnecting the battery -ve first, and labelling the two wires on the switch before disconnecting them.
And then, in the "Haynes Manual Best Practice" it says (and I quote) ... installation is the reverse of removal.
Thanks that's very helpful, i removed the collar using a fencing staple and a pair of pliers - easy. do you know if its possible to buy a new switch?
