Hi, I have taken the plunge and swapped out my front spots and replaced with LED's, the ones with the strip down the centre. I was just wondering if anyone else had swapped out theirs? I am getting error code's for the side markers, the w5 the centre strip. I have ordered some resistors , has anyone else had this issue and how did they overcame it. Anyone using the fogs as DRL? If so how did you set it up?
LED Front lower lights
- Thread starter stephenowen
STiG911
Not exactly the same, but I got an error thrown when I used 'normal' LEDs to replace my sidelight bulbs. Any LED bulb you buy for a 997 needs to be CAMBUS compliant, so it is read and accepted by the fault system. Lot's of options available on a popular interweb shopping site.
Insofar as using the fogs as DRLs - I've heard this is possible by installing a resistor behind the light switch so the come on when the switch is set to 'Home' but I'm not about to attempt that myself. I drive with my main lights on all the time anyway. I've had far too many close calls driving a low silver car on a bright day in the countryside, and having dopey nimrods pull out because they can't see / haven't looked properly. (Usually both)
