Hot!Slow loss of tyre pressure.
C4 MRC
C4 MRC PCGB Member
2020/09/04 10:49:23 (permalink)
I recently purchased a 2011 997 GTS from a good independent, due to surgery the car was delivered by low loader and kept in my garage for a few weeks. I noticed that both rear tyres, recently replaced P-Zeros, were down to c. 16PSI. Since this time I have taken the car out for one decent run to warm the tyres through and have monitored what now seems to be a loss per day of .5 PSI. The dealer has been great and states that if not a puncture (checked its not) this is covered under the warranty. To get this sorted I am going to have to take the car to a local specialist but before I do so does anyone have experience of a similar issue?
Mike Carter
STiG911
STiG911 Guest of the Club
Re: Slow loss of tyre pressure. 2020/09/04 11:02:15 (permalink)
Given that it's happening to both sides at more or less the same rate, I'd say the tyres aren't sealed on the rim properly. They'll need to be reseated.
AndrewCS
AndrewCS PCGB Member
Re: Slow loss of tyre pressure. 2020/09/04 15:24:24 (permalink)
" loss per day of      .5 PSI."
Is this …  5psi or 0.5 psi ?
Aberdeenshire (R2) : Cayman GT4 981
Lancerlot
Lancerlot PCGB Member
Re: Slow loss of tyre pressure. 2020/09/04 19:09:54 (permalink)
Easiest way to identify an air leak is the remove the wheel and immerse it a bath full of water.
The most likely reason is leakage from the tyre valve i.e. a defective or loose valve core. Remove the dust cap and put some spit over the valve opening to check for bubbles. A less common and  often overlooked reason is a porous wheel rim.
Past - 924T, '911 SC, 911 C, 911 C2, 964, 996, 996TT, 997TT, 997GT2, 430 Scuderia, 997TT, 997TTS, 991.2TTS. Macan SD. Raleigh bike!
C4 MRC
C4 MRC PCGB Member
Re: Slow loss of tyre pressure. 2020/09/05 08:24:33 (permalink)
Thanks all, some good tips the 'porous wheel rim' is the expensive one, so off to the independent whilst under warranty!
Mike Carter
MDW
MDW PCGB Member
Re: Slow loss of tyre pressure. 2020/09/24 16:36:59 (permalink)
I've just bought a 997.1 turbo and am experiencing a similar thing. The passenger side rear wheel loses 0.2/3 bar over a couple of days,  and no more. It's very strange. The dealer is going to resolve, as they'd just fitted 4 new michelins.
Human12
Human12 Guest of the Club
Re: Slow loss of tyre pressure. 2020/10/19 21:45:04 (permalink)
I have a similar problem, went to tyre fitters they checked for puncture by immersing wheel in water bath, found air leaking around valve stem seal, have purchased new stem £6 eBay just need to return for them to fit.
