Newbie questions: 987.1
Lawsi23
Hi - just picked up an '05 987 2.7 as a daily - love it! It's a well used (80k) but only 3 owner so as expected, a few things to sort to get it back to a really nice car. I've searched the forum so apologies if these are old issues;
- none of the dash vents work for the up down - is there simple fix or a big job?
- the (original) roof doesn't tuck into the arms when closing - new roof cover or mechanism or both needed?
- the fuel filler flap lock actuator doesn't work - I can hear it clicking but the arm isn't popping out - have looked on You Tube but can only find 986 vids for this issue.
All help much appreciated!
Hi. You'll possibly find this site of use. Focused on the 986 Boxster but much applies to the 987
Ref the roof mechanism there are push rods that break - could be your issue ref item 2.
https://www.pelicanparts.com/techarticles/Boxster_Tech/71-BODY-Convertible_Top_Repair/71-BODY-Convertible_Top_Repair.htm
I've not had issues with air vents nor the fuel filler
This is a useful original Porsche parts catalog:
https://www.porsche.com/all/media/pdf/originalparts/usa/987_usa_katalog.pdf
And this the Service Manual
https://cardiagn.com/boxster-boxster-s-model-year-2005-service-information/
Iain,
I would imagine that the fuel filler flap actuation on the 987 is very similar to that for the 986 so I'm sure the video would be OK for guidance. Maybe there's something for the 997 which will be identical to that for the 987?
Can't help with the hood I'm afraid (I don't have one on the Cayman!) and like Richard I've not experienced or heard of problems with the air vents. Are you saying that none of the 4 individual vents move in the vertical plane, although they move freely horizontally? Weird!
If the roof problem is that the fabric of the roof is not going into the ridge over the windows then this a quick fix. The elastic that pulls the roof into place will have stretched and needs tightening. Loads of vids on YouTube.
The fuel filler cap is a bit more involved. I sorted mine out. If you search for a thread called "Fuel Filler Cap Madness” you will get a handle on what’s needed.
The air vents I can’t help with
Hope this proves useful. Good luck.
Mike
Thanks all, that’s brilliant! That’s def the roof problem, look forward to tackling that and the fuel flap.
The air vent tabs are there and move but it looks like the bits of plastic that move the up/down flaps inside the vent have fallen off - one for the future.
Really appreciate all the help - great to join another part of this community! ????
the videos to repair this mostly show stapling in a new bit of elastic - but I found sewing in a new bit is nearly as easy and a lot better fix for the long term - no big deal - just get some new elastic off ebay (you need the 20mm wide slotted type with holes down the middle) and then sew a new bit in and hook it around the torx screw at the other end and tighten down.
I was lucky, I was able to simply adjust the elastic strap one more hole each side...worth trying that first ??
Hello! I have the same issues with the air vents and the roof! The roof is as already suggested by others, a relatively quick fix and something you can solve (for every lowering/raising) yourself by stopping just before fully closed and tucking them in. After I'd done this for a while they seemed to drop in by themselves more often...
The air vents I've no solution, but I want to know too! Like you, ALL of mine are broken, which seems weird. You'd expect the most commonly used one(s) to go, but ALL of them? Just like you, it appears that there's a disconnection between the lever on the front and the vanes(?) themselves, looks like a broken link. I'd hope to 3D print replacements but I've no idea how to get at the insides and am wary of poking and prodding in case I break something else or run a screwdriver through the dash...
Jon
Jon
i fixed the roof following the helpful links above - it only took about 20 mins. Just need to reapply the window frames from som previous owner levering the roof into them with a screwdriver by the looks of it...
The air vents looks more hassle as the y are all missing the little plastic black ‘forks’ that Move the horizontal slats up & down - the fixes I’ve found on line all have the part Present - mine are all missing - they might have fallen off and dropped down into the ventilation pipes but seems unlikely and that looks like a dash out job. I can’t find new adjuster parts anywhere and a new vent is c£100...I’ve just used a pen to adjust them. Let me know if you find a fix.
Thanks, that's a useful thread, but removing the covers sounds like a complete pain and I just know I'll break one or two parts if I try and do it.
Jon
Buy yourself a set of good trim removal tools and just take removing them steady. It is a little scarry. But it can be done with a little patience. I didn't break anything!
thanks - did you find a supplier for the adjustment ‘forks’?
You mean my modified key tops I assume? So, yes, Ebay:-
https://www.ebay.co.uk/itm/COLOUR-KEY-CAP-CAPS-TOP-COVERS-TAGS-ID-MARKERS-KEYRING-MIXED-COLOURS-CAPS/173912595132?var=472668746585&hash=item287dff9abc:g:3YkAAOSwr6Rc59pv
