OliRThat's very interesting, so if I didn't go for the clubsport package, I'd still be able to install the harnesses, and save the best part of £3k in the process, does the roll cage do anything other than take up space above the engine?
AndrewCSpp Twinfan … and stones can get trapped Discovered that this had happened to my `iron brakes` with the original owner at 1,000 miles. One new disc and pads both sides, cheap fix !
AndrewCSFor a weekend / track car … ditch the `lux options` and choose a light / bright colour with the CS pack.
MotorheadI guess roll cage creaking rather than rattling would be a better description Dave. It's a bolted-in fitment so I guess you may need to tweak the bolts on occasion to maintain a firm fixing. Maybe now would be a good time since you've done some road running and things should have settled down? It might even get rid of the 'ping'. I must say I hadn't appreciated just how expensive the 'full package' was: Full Bucket Seat, Clubsport Package and Passenger Harness - not much change from £7k..! All credit to you in your quest for the full GT car experience. Jeff
TwinfanMotorheadI guess roll cage creaking rather than rattling would be a better description Dave. It's a bolted-in fitment so I guess you may need to tweak the bolts on occasion to maintain a firm fixing. Maybe now would be a good time since you've done some road running and things should have settled down? It might even get rid of the 'ping'. I must say I hadn't appreciated just how expensive the 'full package' was: Full Bucket Seat, Clubsport Package and Passenger Harness - not much change from £7k..! All credit to you in your quest for the full GT car experience. Jeff No creaks on my car Jeff, and the pings are perfectly normal as the chassis moves about a tiny amount. No need to adjust anything here Like I said Jeff, my car has almost every option on it as I plan to keep it a long time unless something changes or a better option for me comes along. You only live once and I splashed out majorly! I'm glad I did as the car is fantastic. I learnt my lesson from my GTS where I ignored the extra cost and added a few options at the last minute. It was the best thing I did, they really finished the car off for me. Just an exhaust change to go now on my car, which I have in hand
