Wobbly drivers door mirror glass
Tizzy
Hi guys, I think this might be a new one! The glass on my drivers door mirror is loose and the faster you go the more it wobbles around, getting quite blurry at "motorway speed”. Outer housing is solid as a rock and the electric operation is fine in all planes, so it seems to be whatever the glass is stuck too. Obviously I’m rather nervous about trying to wrestle the glass out as I don’t want to break it! Anyone had this and any suggestions very much appreciated as it’s pretty annoying!
Many thanks
Chris
Hi Chris,
Been there, done that, lol
You shouldnt break anything prizing it out. Put the mirror by using the internal switch, to give you a big gap at the edge. Prize it out gently, (i used a wooden thin spatula) to encourage the glass and plastic heated piece it sits on, out.
Try and catch/hold it, but the wires for the heated back will keep it from falling out. Detach the wires (remembering what goes where for re-attaching).
Gently remove the glass from the plastic. Clean and dry both sides to be re-attached. Use a double sided tape (or padded double sided tape) to stick back together, Or, a glue that will expand and retract (unlike super glue) with the hot and cold. Clip with pegs to help it stick for a good amount of time and replace.
Not too hard a job.
Hope it all makes sense
Ta
Mark
Yeap happened to me last year. Once cleaned I used a clear mastic to put mine back in place.
Wedge the mirror with wooden clothes pegs back into position. leave overnight before removing pegs.
Thanks for the prompt and helpful responses guys.
I had a few minutes this morning to have a look at the mirror. I duly angled it in and went to try to move the outside edge and the glass literally came straight off in my hand (luckily) - the adhesive bonding it to the backing piece had failed completely - which I guess was why I noticed it getting progressively worse on my journey back home yesterday - I was incredibly lucky that it didn’t just fall off into the road - it must have been minutes (or a big bump) away from doing just that! Anyhow following the advice given I used several strips of very sticky double sided number plate tape that I had in the garage and stuck it back on the backing piece - I guess the heating won‘t work as well now with a small gap, but as my car is garaged and won‘t be getting much winter use I doubt I’ll be needing the heat function anyway. I’ve yet to drive it to prove that it’s worked, but 99% sure it will have done the trick, thanks again!
Chris
Heating should be fine? The element in mine is on the glass and the pad adheres to it. I've found that the red 3M double sided (with a thin foam strip?) works best for me.
