Stop start 992
Dick Dastardly
Missing that nice button in the Cayman to turn off the stop/start when you get in the car.
Does anybody know if the auto-stop start function can be disabled without going into the PCM at start up?
Can this be programmed onto one of the quick access buttons?
If you have the Chrono package, it is possible to programme the ‘individual’ setting to include the stop/start to be disconnected. However it still has to be rotated to ‘individual’ each time you start up.
Dick Dastardly said:
Thanks I do have Sports Chrono so will give this a try when I work out how to do it!
Here are the instructions for programming the Sport Chrono mode button....
[h2]Configuring INDIVIDUAL driving mode[/h2]In the INDIVIDUAL driving programme, the settings for the chassis, vehicle level, sport exhaust system, rear spoiler and Auto Start Stop function can be combined on the basis of the NORMAL, SPORT or SPORT PLUS driving programmes. The saved combination can be retrieved by turning the mode switch to INDIVIDUAL or via the PCM.Selecting and storing settings under INDIVIDUAL
  • Select CAR >. DRIVE.
  • Select the desired settings in the PCM.
  • Select [IND] in the screen header in order to save the settings.
