Does anybody know or can recommend an engine specialist who would be able to inspect an engine in bits and talk to the lad that has already worked on the engine in order to provide an independent expert witness report on the findings from that engine. The engine in question is a 2.4S off a 1972 Porsche
In short, had some work done on the engine, which wasn't right. Then had a.n.other do some work on the engine to try and solve the problem but it didn't and now the engine is back in bits for the second time having now found more problems as a result of the works does the first time around.
So the report will need to be based upon a conversation with the engineer that now has the engine, which is in bits, has carried out work already not at engine with more to do
