Porsche Mechanic required
kmgrace
Hi can anyone recommend a reliable porsche mechanic that would come to my house and help me to recommission my 911sc which has been stood garaged for a number of years.
I'm located in Wakefield area
Hello Martin.
What is it exactly that needs doing to your motor?
Are we talking a basic recommission following a period in storage or a full on body and mechanical rebuild or somewhere in between?
Is your motor currently mobile and on the button or needing work before it can be started up?
Best regards.
Zeusy.
I expect it to be more likely recommissioning thats required, she has been stood for around 20yrs in a garage away from the elements.
My main cause for concern is ensuring all proper checks are made so am able to start engine without damage then moving to ancillaries so will drive safe and be roadworthy again.
Martin
Hello Martin.
Pm me and I will put you in touch with someone who I use who does first class work.
Best regards.
Zeusy.
Hello Martin.
I seem to having a bit of a problem sending my reply to your pm.
I will see if I can get it sorted out and try again.
Regards.
Zeusy.
Hello Martin.
Sorry but for some reason I am unable to reply to your pm - so if you want to pm your e-mail or phone number to me I will send the details you need.
The chap I know has just finished building up a road / track 996 3.4 C2 for me from a bare shell and he does really excellent quality work with great attention to detail. He is currently involved with a full ground up nut and bolt rebuild on an early Range Rover but is pretty flexible and able to fit in other work around projects like this. When I called in recently he had a Ferrari F40 (well …….. erm ……. I suppose someone has to own them……..) on his ramp for a service - but don't worry his rates are always very reasonable.
Best regards.
Zeusy.
