oil pressure question
richardfleming
richardfleming PCGB Member
2020/04/17 20:12:19 (permalink)
had my gts parked up for last 3 weeks or so (longer sitting than it's done before due to lockdown) and went out today to get some shopping.
and I noticed a curious thing on the oil pressure/temp gauge I thought I'd ask you guys about
from cold start (11 degrees C here this morning), did a 15 minute run to supermarket - oil temp took most of the way to get beyond 70 degrees, and oil pressure suspiciously high - hitting 3.1 with revs near 3k - driving gently.
on the way back (after it presumably warmed through a bit better), 3k revs was yielding oil pressure of 2.6/2.7 bar max, temp about normal and all was well.
so my question is... is this normal and just due to cold engine and cold oil, or is this abnormal.
all running fine and if I didn't have the figures on the dash to look at I'd never have known - and rather academic as OPC shut anyway - but thought curious as it's not done that before - but then again not been parked up as long before either.
Don't worry? or worry?
991.1 C2, 987.2 Boxster, Macan GTS
hdoherty
hdoherty PCGB Member
Re: oil pressure question 2020/04/18 06:18:16 (permalink)
It would not worry me.
930 turbo
993 turbo
996 4s
997 turbo
Speedster 3.2
997 gt3 gen 2
Cayenne Diesel
991s cab
richardfleming
Re: oil pressure question 2020/04/18 08:21:49 (permalink)
hdoherty
ok thanks
tscaptain
  • Status: online
tscaptain PCGB Member
Re: oil pressure question 2020/04/18 08:27:01 (permalink)
You may find this useful
https://www.porscheclubgb.com/forum/tm.aspx?m=1042574
The actual oil pressure is dependent on a number of factors with these electronically controlled oil pumps which appeared in Porsche cars in the 997.2 (try flooring the accelerator and see what happens to the oil pressure) so I would agree, as above, nothing to worry about.
Alan Stoneham R15 Joint RO
928 S4 Silver
SWMBO 997 GTS Platinum silver
Following: @PCGB_997
