Yes, I've done it several times in a 996C2, 997.1 Turbo, 997.2 Turbo S and 991.2 Turbo S. Great fun and you'll enjoy it.
The tip I was given on the first occasion was "Don't think you know the circuit until you've done it 100 times"! [
That's good advice! You often think you know what's coming next, then find you're on a completely different part of the track. [
There is a lot of footage on YouTube which is worth looking at to become familiar with how it goes. When possible, keep left when overtaking and right when being overtaken.
Drive some early laps at comfortable speed to get the feel of the place, then gradually increase speed as you become more dialled in. No need to prove your credentials as a driving god first up! [
] Make sure your tyres are in good shape, tyre pressures are correct after each lap and your pump works as you'll need this for your onward journey. Get a nitrogen fill if possible before you go since this stabilises the pressure for longer.
In a Turbo S, you'll have the capability of catching most of the other cars on track, so assume each is being driven by an idiot and give it a wide birth. But don't worry if you're being overtaken or be tempted to drive outside your comfort zone - just concentrate on your own performance. Many locals have done hundreds of laps - and others fly off the road into the trees!
You'll only look a real prat if you stick it into the Armco, so don't spoil your holiday by doing damage - keep it on the black stuff and enjoy. [
