Fuel line replacment
- Thread starter Mickb248
edh
On mine, the bushes for the torsion tube & the suspension arm were fine, but the ones for the arm that comes off the torsion tube were shot. They are very ££
I replaced mine with solid / semi solid mounts anyway, as it's a track car. I wouldn't do that for a road car though as it increases noise.
Waylander
but The cost of a large flare kit for single use might negate the cost saving a bit, and the cost of a roll of 10mm and 8mm might put you in the same ball park as genuine lines
and of course an element of skill is required to make them
vitesse
Active member
When I last looked ,the decent double flare toolkits were near £200 & just not viable when I can get 3 brake pipes including flares & all fittings for £18
Mickb248
will let you know how It pans out but first I have to do some DIY stuff in the house ( got to keep the other half happy to earn garage time.... )
