Wheel spacers/shims
jamesoc
Can anyone recommend the correct shim or spacer size I should use on my 1988 Targa to bring the original 16" Fuchs out without fouling?
James
My coupe has 6mm front and 9mm rear spacers on 16x6 and 7's, respectively. They fill the arches nicely with no fouling.
As I mentioned via email, if you have 6" & 7" (you need to take them off and check) Front 7mm shim, easy fit, rear 15mm shim need to replace studs though!
