Wheel spacers
Edwill997
Hi members, has anyone had experience fitting wheel spacers to their 911 997.1's? If so what size did you use front and rear and if anyone knows of any reason not to I would be glad to hear your thoughts. I've seen a few pictures of some with them and they look well filling out the arches, as standard the wheels seem to be well set in. Any opinions welcome ... Thanks. (Mine is a cab)
Edward,
I'm not sure whether this will be of any help but there was a recent post on the Cayman forum which could be useful (from Post #9):
https://www.porscheclubgb.com/forum/tm.aspx?m=1044598
Although it's for a 987.2 Cayman R, there will be similarities to your 987.1 911 ... the front end will be exactly the same for instance, although your rear suspension will be different. Wheel offsets and wheel arch clearances are the limiting factors of course, and you'll need appropriate longer wheel bolts.
