Porsche 996 Turbo clutch slave servo
dick54
I have a 996 Turbo and I'm told I need a clutch slave cylinder. Part No. 99611623752, Is there a repair kit for this item?
I can't see a repair kit in the Porsche parts catalogue. I don't think they do repair kits for any of the slave cylinders, so if you found one it would be an aftermarket item. It is such a time consuming job to change it on a Turbo (about 4.5 hours), I wouldn't wan't to risk a repair and have to do it all again. Also, it might be the accumulator which is leaking, so until you get it off you can't be sure what is needed.
