987 headlight adjustment
911hohoho
Hi all,
so this prob been asked before but I have searched and cannot find anything
my boxster 987 headlights are dipped pretty low only lighting up a few yards of the road I was looking how to tilt them upwards but don’t seem to be able to find anything telling me how to
full beam is super and lights up so much
any help appreciated
cheers
Jojo
Jojo,
Have you checked that the bulbs are the correct type and are located correctly? If not then it may be worth the effort making sure before trying anything else.
This link is for a 987.2 but is a good starting point for checking the bulb fitment and headlight adjustment http://www.porscheownersmanuals.com/2011-boxster-manual/1/222/Bulbs
Correct headlight adjustment requires specialist equipment of course which your local Porsche Centre or Independent should have available.
glenn duval said:
Any garage that does MOTs can do this for you. Had mine done on my 981 for a couple of pints.
My regular MOT garage didn’t have the necessary extended Allen key for my 987.2, luckily I had one in my own tool kit.
Have you checked that the lights are not set for driving on the right, that reduces the range of the dipped beam significantly?
Check the manual for instructions.
