Bill Gammon
Hi l have fitted Oil pressure and volt meter gauges but am struggling with the Oil temperature gauge , l tried a sender with tee on oil pressure output port but it only registered very low temps, because l think the oil was not circulating only static .I am now looking at the Oil drain plug with the sender fitted there. Or is there a tapping Somewhere that l could use for the temp sender. Any advice.
