Sandspider
Hi all
I seem to have a leak from my power steering (reddish fluid dripping from the front right of the car). Need to get under it and see where it's coming from, but first question, what's the correct stuff to fill it up? Dexron III ATF? Is that even available any more?
Are there any likely contenders for a leak from this area, before I start burrowing underneath?
Finally, the steering is now (obviously) quite heavy. Will driving it without fluid / with low fluid damage the pump?
The power steering belt was replaced quite recently, but I seem to be getting other steering issues now.
Thank you.
Thank you.
