farleton
I have a 987 Gen2. When my car was at OPC for a major service and MOT recently reported that there was excessive wear on the extreme inside edge of the off side front Tyre. Not enough to cause an MOT failure but they suggested that I get the tracking tested. This has been done and the tracking was spot on. When I examined the tyre the wear was very pronounced and not smooth. Having just read Cobnut's post about the RAC I took the decision to change both front tyres with a the same make and model of the tyres on the rear. I wonder whether anyone else has experienced the problem of excessive wear on only one front tyre and whether anyone has an idea of what may be causing this. I do wonder if this could be a speed hump problem. In our vicinity we do have a number of speed humps of the type that can be straddled by cars with sufficient ground clearance. They are too high for the Boxster so I tend to position the left hand wheels on the kerb side of the hump and mount the hump with the offside wheels. All this is done at a very slow speed. There is no corresponding damage to the off side rear tyre maybe because they are wider.
