Bosch fuel pump
- Thread starter vitesse
AndrewCS
Active member
Also found on Saab and Volvo, less scene tax perhaps []
Waylander
vitesse
Active member
I sort of agree so have shelved the new pump for now-funnily on leaving the PCGB track day on Friday late pm,it went round the clock through the gears but then returned to the blessed 4500 rev limit once hot,so after consulting my Bosch Fuel injection manual,my conclusions initially are to check the coil(DME rev limit comes from its signal),coil wiring(possible break opens up when hot ) & DME connection(s) before swapping out the DME from my wife's car to see if there is any difference.
Rob-a bit more info for your sake too.[][8|][&o]
vitesse
Active member
At present have discounted the AFM because below 4500rpm,car goes very well with no problems & settles back to even idle once at rest.
Have dug out a spare engine temperature sensor (Bosch plug type) & spare coil,plus made a note of all appropriate wire colours ready to check out the critical connections to the DME plug,prior to swapping components.Going a bit into uncharted territory for me going forward.
Plus point is that I can drive it at motorway speeds still as long as in 5th gear[]
vitesse
Active member
Current thoughts are:-the problem appears totally temperature related so unless the AFM tracks get hot enough to give funny signals I am discounting it being faulty for the present but- I haven't checked it yet cold & hot for lack of time & the weather.
I still haven't checked the DME connector unnconnected for the same reasons & so far haven't found any info that pinpoints the problem,even my Bosch manual doesn't address this.Most technical help relates to cold start,idle issues or uneven running problems associated with injectors-help!
