Hot!Stripped cam pulley bolt
James0
James0 Guest of the Club
2019/08/24 19:09:48 (permalink)
Evening,
just doing the belts and front seals, going well until I stripped the cam pulley bolt. I'm aware it's a fairly common occurance and I'm tempted to just not change those seals and put it back together.
Anybody done this before? Is it a case of drill it and the rest is easy once the pulley is off, bearing in mind holding the cam still whilst extracting the remains of the bolt will be a challenge at best.
13 Replies Related Threads
    Waylander
    Waylander Guest of the Club
    Re: Stripped cam pulley bolt 2019/08/25 01:03:29 (permalink)
    Grind the head of the bolt off, and once the pulley is out the way and the tension is off the bolt you should be able to undo the remains easily with a pair of pliers or mole grips while holding the cam still, if your a bit concerned about the cam just put the belt back on  and will all rotate In the right timing
    1992 Cobalt Blue 968 Coupe
    James0
    Re: Stripped cam pulley bolt 2019/08/25 17:14:33 (permalink)
    Thanks, a bit of googling suggests the same but an actual person confirming that helps.
    I must admit the thought of drilling the bolt makes my teeth itch. If there wasn't a bit of an oil weep from the cam I'd leave it for next time.
    Went racing on the push bike today so I'll probably get on it tomorrow when I'm not shattered.
    dlknight
    • Status: online
    dlknight PCGB Member
    Re: Stripped cam pulley bolt 2019/08/26 16:33:49 (permalink)
    Same happened to me when I did the front end reseal - you need some good quality HSS drill bits. Then you need to drill the head off the bolt - it should come off fairly quickly if you have good drill bits. I had to get a right angle drill extension as I couldn't get my drill in-line with the bolt due to the radiator being installed. Don't go too deep - just enough so the head will pop off as you will probably want enough of the shaft visible (with the pulley removed) to get a good hold of with vise grips. You should now be able to remove the pulley and then from everything I read the bolt should come out with finger pressure.... well mine didn't but a good soaking of penetrating fluid over several days and then a good pair of vise grips got the **** out. Don't use any thread lock when you put it back the torque alone will hold it on. Make sure the new bolt is the uprated one (cheese head instead of allen), Porsche updated the bolt so that the higher torque could be applied to stop the bolt coming undone.
    post edited by dlknight - 2019/08/26 16:35:03
    Current
    1990 Panther Black 944 Turbo
    2000 Violet Blue 911 Carrera 2
    Gone
    1987 Alpine White 944S with ProMAX Performance Chip
    '88 Black 944 2.5, '96 Pug 306 XSI, '72 VW Type 2 Dormobile
    James0
    Re: Stripped cam pulley bolt 2019/08/26 18:21:14 (permalink)
    Well my drill bits can't be that great. Gave up at about 3pm when the right angle drill adapter got insanely hot and ordered some Tungsten Carbide bits. That bolt is harder than old Weetabix.
    Waylander
    Re: Stripped cam pulley bolt 2019/08/26 20:14:32 (permalink)
    A proper 15.2 bolt, time to get the angle grinder out
    James0
    Re: Stripped cam pulley bolt 2019/08/26 21:22:48 (permalink)
    I'd have to ditch the distributor if I got the angle grinder out, something I can do with my ECU but I could do without the extra work for marginal gains.
    That or buy a replacement cam pulley.
    James0
    Re: Stripped cam pulley bolt 2019/08/26 21:57:06 (permalink)
    Actually scratch that, forgot the carrier is separate and can be cut, I'm reluctant to though.
    Waylander
    Re: Stripped cam pulley bolt 2019/08/27 08:18:32 (permalink)
    Ohh yes I keep forgetting that the 944 is different to the 968
    when my cheese head just stripped out I just ground the head off bought a new bolt and nut, job done
    robdimond
    • Status: online
    robdimond PCGB Member
    Re: Stripped cam pulley bolt 2019/08/27 09:02:22 (permalink)
    Rotate the engine 45 back degrees so no pistons are at TDC, then it doesn't matter how much you turn the camshaft.  As I recall this is the workshop manual procedure for removing the camshafts.
    '89 944 S2 Guards Red
    '01 E39 M5
    dlknight
    • Status: online
    Re: Stripped cam pulley bolt 2019/08/27 16:58:24 (permalink)
    Not sure about titanium drill bits - everything I read said to get cobalt drill bits.
    I picked up this 5-piece set of Irwin Cobalt drill bits and they went through it in no time after I'd done the same as you with standard Makita HSS drill bits -
    https://www.amazon.co.uk/IRWIN-10502570-Cobalt-Drill-Pack/dp/B00MOB16TM
    Don't forget to lubricate the bit - I made a concoction with some engine oil and fairy liquid...
    Current
    Gone
    James0
    Re: Stripped cam pulley bolt 2019/08/27 18:20:05 (permalink)
    According to drill bit manufacturers, Tungsten Carbide drill is what you want for hardened steel. I can't say that out loud without a northern accent , badly mimicking the Monty Python Sketch. Working  class playwright I think?
    James0
    Re: Stripped cam pulley bolt 2019/08/27 19:40:34 (permalink)
    Well, knife through butter springs to mind. Well worth £10 for one bit.
    The remains of the bolt pretty much fell out.
    It seems I had more than a weep at the cam seal and it must have mostly been burning off on the exhaust manifold.
    Waylander
    Re: Stripped cam pulley bolt 2019/08/27 20:05:35 (permalink)
    A correct bit of kit always makes a task easier
    I bought some bits from Screwfix that had a pilot drill built in, they were really handy for drilling out flush sheared off bolts
    glad you got it out and the job can progress
