356B 1962 rear axle bearing flange oil leak
Markethouse356
I've recently bought a beautiful old car but unfortunately the rear bearing O ring has leaked onto the brake shoes. It was restored 10 years ago and on inspection the rear axle bearing flange has been damaged so that the O ring between the flange and shim will not seat and hence leak. I would be very grateful if someone could advise how to remove the axle bearing flange together with the half shaft tube that is shrunk onto it. Many thanks
you are more likely to get help by posting on DDK Website.
it is specific to early 356 and 912 cars.
D
It is worth joining the 356 Registry, you won't be able to post there and ask questions without membership but you should be able to use the search function to find the information you need if the question has been discussed before.
DDk is a UK based early Porsche site with a very active and friendly forum. Free to join and I'm sure somebody will be able to help.
DDK-online Porsche forumwww.ddk-online.com/
Michael, This is quite a job, not least in removing the axle shaft nut which is 350 ft lbs or more. You also need some special tools to remove the wheel bearing which you may like to replace.
I would seriously suggest the you have a specialist do the job unless you are a competent mechanic.
You do not say in what part of the country you are located, general area info would help send you to someone capable.
I have copied the relevant pages from the workshop manual to help you see what is involved, unfortunately in this modern forum I have no idea how to attach those images to this posting, so email me on robinjowalker50@gmail.com.
copy image location
and I will email the 4 pages to you.
