New 930 Turbo Owner and the Start of a Project and First Help!
SiJ
Hello All,
Just when I was not really looking, I have entered into the 930 Turbo ownership. I've had a 914-6 GT conversion for over 12 years and love it, but always had the dream of a 930 Turbo.
Through a friend, I've managed to acquire a rarely seen example that's been garaged for over 10 years with little use.
It's solid, but has been modified. My project will be to sympathetically put it back closer to stock.
It has the following;
Running 450bhp with K22 hybrid turbo. Exact one to be determined.
Aftermarket intercooler.
Replacement lower body sills, all around.
18in alloys.
Elephant suspension upgrades.
So here is the first request for help, it was running perfectly but I think the injection control unit has packed up. No current to the coil. The unit makes the right sounds on ignition.
Has anyone used one of the CDI+ boxes from Design911. They look just the ticket with modern tech to improve the overall running while looking like the original box.
Once it's running again, I'll post some pictures and the details / histories and hopefully meet some of the 930 Turbo owners out there.
Cheers for now
Si Jackson
Hi Si
I have a totally standard 1988MY car with 65k on the clock, I have owned it since May 2008. Great cars, you won't regret it.
My CDI box failed about 5years ago and I sent it to this chap (Lutz Gerberding) in Germany.
https://www.911-hkz.de
Lutz told me why it failed, repaired it, upgraded it and gave me a 5year guarantee for €250 plus postage. Highly recommended.
If you need any detailed photos or any other details of my car at any time let me know.
Craig
Cheers Craig,
I'll check him out and see what happens. Looking forward to getting it going again. I'm taking this as part of the shake down process!
Si
Thanks All,
Oh the joys of classic car ownership. Thanks John for the recommendation. New Classic Retrofit CDI+ box, new relays and new green signal wire into the distributor and we have a spark and it starts.
Two days of joyous motoring and then the rear nearside bearings collapse. New bearings all round and back on the road.
Now after a month in the garage due to the weather, the idling is very lumpy and no acceleration. It feels like it's firing on 5 cylinders. So checks are about to start. I'm thinking of checking the following:
Ignition leads
Vacuum hoses and seals
Fuel pumps and relays.
Have I missed anything?
BTW, here's a picture.
De42kCZ8RVJytvFX7
Cheers for now
Si
Glad the CDI box worked out Si and that you got some miles under your belt.
Sorry to hear about the bearings - been there, done that!
Your latest fault finding list seems to be sensible - I’d check the coil as well as replacing the leads.
Cheers,
John
