Lee997
hi all, my 997.1 is suffering from slow starting and I’m aware of what needs to be done however today while out it refused to start and I had to wait a while but fortunately after a few tries it restarted.
on the way home I gave it a large amount of throttle while banked on a roundabout (didn’t notice exactly what gear it was in but probably 4-5th), I got a error stating triptronic emergency run and alternating gear lights flashing between neutral and 5th.
i had to pull over and switch off to and restart to clear it as it was also in slow mode.
after a bit more driving I tried the same thing that caused the error the first time, again’t under heavy acceleration while hard in a roundabout I got the same error " Triptronic emergency run” again required a stop restart to clear.
so I’m after opinions please but wonder if it was due to maybe the box reading the situation as requiring to much power while in a bend and a lot else going on at that moment what with power being sent to what wheel as well as PASM?
Lee.
Lee.
