Noticed damp carpet in the drivers footwell this morning after a wash.
PhilKent
PhilKent PCGB Member
2019/05/19 18:29:49 (permalink)
Any tips on where to start looking? It's a cab. No obvious signs of where it's getting in.
PhilKent
andywill
andywill PCGB Member
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/19 21:59:36 (permalink)
Hi Phil.
I would suspect a rear drain blockage to be a possible suspect, VERY important that you don't let water get in contact with all the electrics under the passenger seat which can cause costly problems. I have posted two articles in Porsche Post about it. see link below go to Page 97
https://www.porscheclubgb.com/news-and-events/porsche-post/2017/october/porsche-post-october-2017
good luck
Andy
post edited by andywill - 2019/05/19 22:00:42
Andy Willis.
996 Register Secretary.
996@porscheclubgb.com
07775 138527
PhilKent
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/19 22:29:47 (permalink)
Thanks for the info Andy, I'll take a look at those drains asap.
PhilKent
robgroves
robgroves PCGB Member
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/20 19:46:26 (permalink)
If its in the front it will be coming in from the area in front of the windscreen, where the battery / wipers are, there are two drain holes there that get blocked up with leaves etc that allow water to build up and enter the cabin. Pull the plastic cover off and you will see, the drain holes are not obvious but have a look on google! This especially happens when washing as your using much more water than just rain.
PhilKent
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/20 21:22:26 (permalink)
Thanks Rob, that sounds more likely. I'll take a good look at those drains at the weekend hopefully.
PhilKent
robgroves
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/20 22:23:33 (permalink)
No worries, mine had the same. Might need an airline to blow them through, the one on the driver side by the battery tray is easy to get to, the one on the passenger side a bit more tricky.
PhilKent
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/21 22:09:00 (permalink)
Airline maybe a good plan. I know on my 944 I avoid air on the drains as there are some not so strong unions that may split or burst if blasted with an airline. Any such risk on these?
PhilKent
robgroves
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/22 22:38:58 (permalink)
I think on the 996 they are a solid pipe at the front, but a gentle blow through should be fine, to be honest you'll probably see the blockage at the top of the hole anyway
robgroves
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/28 19:16:11 (permalink)
How'd you get on Phil?
Roger Goode
Roger Goode PCGB Member
Re: Noticed damp carpet in the drivers footwell this morning after a wash. 2019/05/28 21:57:54 (permalink)
After I discovered the same problem I had to go to see my GP.  I’m waiting for an appointment with a geriatric specialist.
I hope you solve the problem Phil.
R7 - CoG (Co-ordinators Group) member
987.1 Boxster S
996.2 911 C2 Coupe
944 S2 Coupe
