996c4 cabrio engine squeak
k31thj
Hi, need a little help on my 996c4 cabriolet.
When running at a normal temperature and idling I have a squeak from the OSR wheel area; does not come from the engine compartment as I have removed the air box and checked belt etc. The car runs fine and has no leakage of any fluids. The sound is like a valve operating,like a vacuum problem. Are there any components under the soft top I can check? Not sure if I should be looking for a loose spark plug even.
Thanks for any help
Keith
Hi Richard
many thanks, have found the loose plug and all ok now. It was the hardest one to access of course, car running noise free again
Keith
