996 + Koni Special Active = Perfect GT car?
cjrhodes
Hi All
1 year into owning a 2001 996 C2 coupe 3.4 76K miles sunroof delete 18inch BBS split rims - and loving it.
Various work done to date including IMS, Clutch, Waterpump, Coffin arms, Tuning forks, bushes, steering rack bits and bobs and a full geo suspension check and alignment with Chris at Centre Gravity.
Now I’ve got the car as near to standard and as set-up as possible and I’m reasonably happy. Most of my driving is 60% UK bumpy B roads and 40% fast A roads. I like a fast GT car feel as opposed to the full teeth rattling racing everywhere like a nutcase Cayman gig.
Question..I’ve been contemplating a suspension upgrade and I’m intrigued by the new Koni Special Active dampers.
My car is on standard springs that have "settled” such that the ride height is approx 10mm lower than it would have been out of the factory. The Koni dampers seem to be new technology similar to much more expensive Ohlins and PASM systems - I like the idea of keeping my car as pure and standard as possible but I do wonder if adding these newer Koni active technology dampers could be a really worthwhile upgrade?
Anyone any experience and should I consider replacing springs at the same as dampers?
My dilemma - Koni Special Actives or Bilstein B4’s? change springs?
I like the current ride height and have no desire to change/lower.
Thanks in advance for any thoughts/comments/experience.
Colin
Hi Colin.
My advice would be to give Chris Franklin at Centre Gravity a call. He is one of the best in the business with regards to Porsche suspension setups. Tell him what you want out of the car and he will give you the best advice. There is no point in getting the best all singing components as they will not always give you the end results you require.
Good luck and please let us know how you get on.
http://www.centregravity.co.uk/
Kind regards
Andy
Thanks Andy - I called them on Friday and hope to speak to Chris on Monday.
Seems that the Koni‘s. are popular with 993 owners, am keen to find anyone out there with experience of them on an early 996.
Hi, I’m debating the same options with my car, What spec did you go for?
thanks!
