One of my immobiliser fobs has stopped working, My first thought was a new battery but it still doesn't work, no show on the red light when pressed, Does anyone know where I can get it looked at please.
Immobiliser Help Please
- Thread starter jonnyporsche
I would try contacting Hamilton and Palmer http://www.hamilton-palmer.co.uk/ they were able to provide me with a new immobiliser 'plug in key' a few years back, they might be able to sort a replacement fob - I believe they supplied the remote unlock/lock too, but my 90 didn't have the remote fob, just arm/disarm when you locked the doors, my 91 had a clifford fitted before I owned it so not sure what it was supplied with.
Tony
bmnelsc
You could try a computer repair shop as it is very likely that the "soft touch" switch has failed and the rest of the fob is OK. The "soft touch" switches (the push buttons) have a life of several thousand activations and then fail. From the looks of your fob this is a likely scenario. A search of the internet should turn up a DIY solution to this very problem but if you are not handy with this sort of thing you can let the professionals have a go.
Thanks for your help. Now sorted was a bad soldering joint []
