Helpful ReplyHot!Goodridge Brake Hoses
Diver944
  • Status: online
Diver944 PCGB Member
2019/04/15 11:30:21 (permalink)
I'm just starting to think about my MOT next month and remembered that last years advisory was that the ferrules on the brake hoses had slight corrosion, so I want to replace them and was thinking about Goodridge
Has anyone used Stainless steel Gooridge hoses? Any issues fitting them?
My ferrules look very crusty now, anyone done the job recently, were the old ones easy to get off? Thanks
Paul Smith - Northants 1990 944 S2 Panther Black
PSH
  • Status: online
PSH Guest of the Club
Re: Goodridge Brake Hoses 2019/04/15 13:18:08 (permalink) ☄ Helpfulby Diver944 2019/04/15 13:56:01
Hi Paul
I only have good things to say about Goodridge braided hoses, I recall the words of doom from some against me fitting them to my car a long time ago, before the disc's that I've just changed so well over 15 years, perhaps 19.. I always used Goodridge on my Fords so ignored those against their fitting on a 944. I think nearly 20 years service with no problems and no sign of them needing to be changed anytime soon is good enough testimony as to their value.
Pete
944 Turbo......was 368BHP/382Torque.... now more...
Waylander
Waylander Guest of the Club
Re: Goodridge Brake Hoses 2019/04/15 16:45:49 (permalink) ☄ Helpfulby Diver944 2019/04/15 21:23:57
Agree with Pete totally, only I would say they are slightly longer than standard, route them carefully so they don't rub on any of the brackets at the rear
1992 Cobalt Blue 968 Coupe
Dan944t
  • Status: online
Dan944t Guest of the Club
Re: Goodridge Brake Hoses 2019/04/15 17:41:55 (permalink) ☄ Helpfulby Diver944 2019/04/15 21:24:00
I’ve also fitted these to my 944 turbo. I really like them great quality and I deffinately have a better pedal for them .
The originals can stretch and bulge over time and that is what was happening to me, with braided there much stronger and won’t stretch like rubber under preasure.
atb
daniel
scam75
scam75 Guest of the Club
Re: Goodridge Brake Hoses 2019/04/15 21:11:42 (permalink) ☄ Helpfulby Diver944 2019/04/15 21:24:04
I've had them on about 8 years. All good.
Stuart
'90 944 Turbo - Sunroof delete, Factory bridge spoiler, CS wheels, CS steering wheel, 1st MY90 turbo in UK
Promax L2 chips, SciVision MAF, Lindsey DPW, MBC, Forge recirc valve, 3 bar FPR, K&N panel, GAZ Gold, wideband AFR, Sytec Motorsport Fuel Pump.
Hacki
Hacki Guest of the Club
Re: Goodridge Brake Hoses 2019/04/16 07:19:30 (permalink)
Using Goodridge on my 964 for years now, never had a problem. Fitting was easy. Would for sure do it again.
Hacki
Owner of an inflatable Spitfire and an escape glider
-2- RSRTC
tscaptain
  • Status: online
tscaptain PCGB Member
Re: Goodridge Brake Hoses 2019/04/16 08:18:07 (permalink)
The factory is in our Region in Exeter and we had a tour there recently.  A very impressive place and real quality products for a range of car manufacturers and one top end sports car producer in the UK in particular.
R15 Joint RO
SWMBO 997 GTS Platinum silver
Following: @PCGB_997
Diver944
  • Status: online
Re: Goodridge Brake Hoses 2019/04/16 11:22:26 (permalink)
Cheers guys, I've just ordered a set for some Easter Weekend maintenance.
Changed the disks and pads last weekend so looking forward to stopping on a sixpence
I'm not looking forward to getting the old rusty ones off. Very careful and targeted soaking with WD is in order - eek!
PSH
  • Status: online
Re: Goodridge Brake Hoses 2019/04/16 12:07:19 (permalink)
have fun Paul
As Waylander stated, do be careful in how you route them, I'm sure you will anyway but worth pointing it out...
Pete
944Turbo
944Turbo PCGB Member
Re: Goodridge Brake Hoses 2019/04/16 12:17:37 (permalink)
Diver944
Hi Paul.
Plus gas or Wurth 'rost-off ice' are better than wd40 - If the new pipes definitely look like they should fit, or you dont need the car cutting the pipes and using A ring spanner or socket might make it easier to remove the rusty old ones. Assuming there is clearance for that to work! If not a brake pipe spanner is better than an open ended.
Tony
944T Coupe - personalised ;) but needing work
944T Cab - Standard
IanK
IanK Guest of the Club
Re: Goodridge Brake Hoses 2019/04/16 13:39:05 (permalink)
Just ordered a set from Goodridge - £92 inc VAT for the full kit.
Ian
Diver944
  • Status: online
Re: Goodridge Brake Hoses 2019/04/17 14:54:50 (permalink)
Mine just arrived from Design911 - very swish but they do look an inch or so shorter than I remember my rubber ones. I'll find out at the weekend.
I have got some flared brake spanners, so we'll just see how it goes
Eldavo
  • Status: online
Eldavo PCGB Member
Re: Goodridge Brake Hoses 2019/04/18 00:01:51 (permalink) ☄ Helpfulby Diver944 2019/04/18 08:40:15
I fitted Goodridge to the front and new standard ones on the rear. If you look at the rear suspension setup it causes the brake hoses to twist - something the braided ones aren’t great at handling but the standard rubber tolerates far better. YMMV but each to their own.
Current:
2006 987 Boxster 2.7
2001 996 3.6 C2
1988 944 Turbo S (not exactly standard)
Past:
1988 944 2.7
Waylander
Re: Goodridge Brake Hoses 2019/04/18 00:17:55 (permalink) ☄ Helpfulby Diver944 2019/04/18 08:40:17
Please can you clarify the reasoning behind this statement, full travel of the rear arms is only as far as the shock allows it down and the bump stop upwards, in terms of a circle this can't be more than about 20_30 degrees maximum that hardly describes a twist in the hose, in fact I would think the front flexes more.
I have read this in other places before and there is no real evidence to convince me that this would be dangerous at all, incorrect fitting is more likely to cause an issue, I have had mine fitted for nearly 6 years and I inspected them all at the mot last week and they are in perfect shape after 15,000 miles
Eldavo
  • Status: online
Eldavo PCGB Member
Re: Goodridge Brake Hoses 2019/04/18 00:39:19 (permalink) ☄ Helpfulby Diver944 2019/04/18 08:40:19
A friend raced a 944 with braided hoses and they were fine, another had issues and when he removed them and cut them open they were damaged inside and it was hidden by the braiding.
Depends on a multitude of factors, including intended usage, I was at pains to point out that there was no “right” answer.
Current:
2001 996 3.6 C2
Past:
1988 944 2.7
blade7
blade7 Guest of the Club
Re: Goodridge Brake Hoses 2019/04/18 10:46:58 (permalink)
It's a long time since I've had a car with them fitted, but I've read rubber hoses have a certain amount of 'cushion' and braided hoses can remove some of the feel.
924Srr27l
924Srr27l Guest of the Club
Re: Goodridge Brake Hoses 2019/04/18 16:52:31 (permalink)
blade7
That's the problem, never believe everything you read !
It's Quite the Opposite!
Rubber hoses give / expand and flex more especially with pressure,
hoses can have an braid of nylon or stainless steel over the inner hose for good abrasion resistance but most of the aftermarket sets use a ptfe plastic inner hose and NOT a rubber hose with a  braid over the top.
It's this that yields a higher burst pressure and much less resistance to bulge and flex like OE rubber ones do.
Hence you'll get a firmer pedal with an aftermarket ptfe Inner set, and a softer / longer / more spongy pedal with a Rubber hose.
https://www.goodridge.co....se?variant=32846480007
R
John Sims
John Sims PCGB Member
Re: Goodridge Brake Hoses 2019/04/19 10:55:04 (permalink)
924Srr27l
blade7
R
Well isn't that exactly what Blade7 said?  The only variance is whether you prefer the firmness of the braided hose or the slight give of a rubber hose. So not "Quite the Opposite" at all.
John Sims
