An interesting post on a German Forum:
9A1 Motor ist ja Serie tot, allein schon, weil er keine verstellbaren Auslassnockenwellen hat, das braucht man im Prinzip für Euro 6d und deutlich höhere Einspritzdrücke mit idealerweise wie beim ab 991.2 S vertikalen Zündkerze angeordnetem Einspritzventil.
Grundmotor aber 9A1 Motor.
Die OPF Geschichte dann riesen Akt, beim 992 wird der differenzdrucküberwacht, wie bei Dieselmotoren Standard, dann sollte OPF katnah sein, damit Rußpartikel verbrennen, aber zu heiß darf OPF auch nicht werden.
War früher zu hohe Kat Temperatur auf der Rennstrecke ggfs. ein Problem, hat man dazu jetzt noch OPF Temperaturproblem, bei 950 Grad soll der am Ende sein. Im Zweifelsfall regelt DME kräftig runter.
My German is not good but I think it is saying the 9A1 engine as fitted to the 981 GT4, and presumably the same generation used in the 718 GT4 lacks certain technologies required for most efficient combustion namely camshaft adjustment and ability to run sufficiently high fuel injection pressures. It also notes the 991.2 Turbo engines have a different spark plug/injector arrangement. It also suggests latest 911 engines have pre-cat soot sensors (not sure whether this is an engine design point) as do diesel engines which enable better particulate filtering.
On cats, I think it says the 9A1 runs high cat temperatures which cause issues on track (BGB report race Clubsports requiring regular cat replacements) although I can’t really fathom that point.
Perhaps this and Porsche's issues with 4-way cat system and restarting development on a 3-way cat design also goes some way to explaining why Porsche made the late (October Weissach meeting) decision to keep the 3.8L engine in the Clubsport.
If we have any German speaking engine experts on here, it would be interesting to get an informed view on this. If these points are valid, it would seem that Porsche are unlikely to invest in a new generation engine so 718 in cooking and GT form continue as is/soon to be for another 4 years.
