Rear suspension not level
- Thread starter Stephenjk
https://rennlist.com/forums/964-forum/783668-rear-ride-height-measure-from.html
A visual of the springs for sure for any sign of damage/issues and their seating location. Do you know any history of past suspension work?
Stephenjk
Dekker
If the shocks have been replaced and the springs are OK it could be that the drivers side which probably has the most wear, will need to be adjusted and then the suspension geometry rechecked.
Stephenjk
mcgc0 said:A visual of the springs for sure for any sign of damage/issues and their seating location. Do you know any history of past suspension work?
Been through all of the receipts that came with the car back to 2006 and nothing i can find for dampers or springs so they are at least 12 years old if not original. Some of receipts are in german while car was in zurich so took me a while to google any large part numbers i did find new starter, new headlamp and new distributers that i didnt know about.
Stephenjk
colin129 said:How much are we talking for a suspension refresh & geometry set up?
Just priced up Bilstein B6 dampers and Eibach springs on design911 and with the spring discount (till end of April) they come to £1,139.77 inc vat and delivery. I havent checked other sites but thought that was pretty good. Even with bump stops and some additional tools you could keep it under £1500 diy I suspect.
