Mileage recorder and trip not working
WNX700H
Noticed this after zeroing trip after fuelling the car .... speedometer works but mileage recorder doesn't ...... likely cause and remedy please.
There is a small plastic gear in the speedo which breaks, causing the odometer to stop working. It is a very coomon failure. Here is one source for the gear, but I recall seeing them cheaper elsewhere: https://www.ebay.co.uk/itm/182133766702
Maybe give Matt at Type911 a call, and see if he sells them. It's a bit fiddly getting the speedo apart, and there are places who do repairs. If you want to go that route, I would recommend John Ostick at JDO Instruments: http://www.jdo1.com/
