Interior lights stay on for approx 10 minutes after ignition switched off.
dab996
dab996 PCGB Member
2019/03/01 09:31:33 (permalink)
I have a C2 996 Coupe, which unfortunately doesn't get driven as much nowadays and after a recent outing i noticed a couple of issues, which may or may not be connected.
1. When starting the engine, the ignition doesn't return to its correct position and has to be positioned manually.
2. The interior lights stay on when driving and when the ignition is switched off they stay on for about 10 minutes.
A bit of investigating suggests these issues could be related and its the ignition starter switch that needs replacing and as such i should be grateful for any opinions/advice.
Thanks,
Darren
2 Replies Related Threads
    andywill
    • Status: online
    andywill PCGB Member
    Re: Interior lights stay on for approx 10 minutes after ignition switched off. 2019/03/01 14:14:46 (permalink)
    Hi Darren
    Odds on faulty ignition switch which is a very easy DIY job, it's an Audi part and should cost about £20 from any gsf or euro part shop.
    See link for further info
    https://www.porscheclubgb.com/forum/tm.aspx?m=949957&high=Ignition+switch
    Good luck
    Regards Andy
    Andy Willis.
    996 Register Secretary.
    996@porscheclubgb.com
    07775 138527
    dab996
    dab996 PCGB Member
    Re: Interior lights stay on for approx 10 minutes after ignition switched off. 2019/03/01 16:37:38 (permalink)
    Thanks Andy and much appreciated.
