DME check.
white944
Hi, can anyone remind me.... does the 944 DME turn the fuel pump on/off briefly when you turn the ignition on before cranking like on a lot of 1980s cars, or does it wait for the cranking/ 200+ rpm signals before doing anything. Pump runs fine with relay bypass, and relay appears to be good.
No fuel or spark, relay is sending power to DME, but I don't think the DME is 'waking up'
Thanks.
_________________
AFAIK the DME is looking for 200 rpm before it energizes the fuel pump as a safety feature. I don't know if the ignition is similarly controlled - I would think ignition is active regardless of cranking speed. I think testing the flywheel sensors would be the next step. If it is an '83 as per your signature block - you have two - a reference sensor for TDC and a speed (RPM) sensor. S2s have only one which combines both functions. Also a faulty ground would be a good suspect here.
